English
Problem: Projections in PC ARC/INFO don't line up with same projections done in ArcView
Solution or Workaround
Projecting from geographic to Stateplane NAD 83 does not produce the same results as doing the same projection with Projector! in ArcView 3.x.
Cause
The PROJECT command assumes an input datum of NAD 27 where as ArcView assumes
NAD 83.
Solution
Make sure the Input PROJECT parameters include: DATUM NAD83 NADCON. For example:
input
projection geographic
units dd
DATUM NAD83 NADCON <------this line is added.
parameters
OUTPUT
PROJECTION STATE
UNITS METERS
ZONE 5526
DATUM NAD83 NADCON
PARAMETERS
END
This DATUM definition will prevent the input from defaulting to NAD 27.
