English
Problem: GTCO Utlima and Super L II digitizers don't work with PC ARC/INFO
Solution or Workaround
The GTCO UTLIMA II and SUPER 2 PLUS digitizers don't work.
Cause
Changes in versions of PC ARC/INFO. The 'I' used in 3.4 is no longer valid in 3.5, 'F' must be used instead.
Solution
Edit the digform file for the GTCO ultima and Super L II. Change the format string "..I4,1X,I4" or similar to "..F4.0,1X,F4.0".
The GTCO Super 2 PLUS digitizer is not a supported divice.
