English
How To: Install the sentinel drivers
Procedure
Summary
Steps to install the sentinel drivers for PC ARC/INFO 3.5.1 international version.
Procedure
1. Navigate to the directory called KEY on the PC ARC/INFO CD.
2. Find a file called KEY.WRI. This is a WordPad document that describes the sentinel driver installation procedure.
3. Navigate to the subdirectory under KEY that corresponds to your operating system:
   Windows 311
Windows 95
Windows NT
These subdirectories contain all the files and the driver for your OS.
Normally, Windows 95 installation does not need the Sentinel drivers.
At the time of Install itself you should be able to upload the driver.
In order to make sure you have the correct CD, look for the key symbol on the CD. The part number may be 75192.
