English
Error: Cannot open graphics window. Display device is not defined
Solution or Workaround
Summary
Typing DISPLAY 4 in ARCPLOT or ARCEDIT, in the WINDOWS section of PC ARC/INFO, returns this message:
   Cannot open graphics window.  Display device is not defined.
Cause
The DOS executables for ARCPLOT and ARCEDIT are being used instead of the WINDOWS versions of these programs.
Solution
Double-click the SCRMAN icon to startvthe Screen Manager prior to opening any graphics module. Once the screen manager is running you can start any PC ARC/INFO WINDOWS extensions. To start ARCPLOT and ARCEDIT use the commands ARCPLOTW and ARCEDITW, or select their icons from the ARC program group.
