English
Error: FILE NOT FOUND error
Solution or Workaround
Summary
In TABLES, using 'ADD FROM input_file' command with a file without any extension produces this message:
Cause
TABLES expects all the data files to have extensions.
Solution
Make sure to type the input file name with an extension. If the file does not have one, type a period after the name, that should solve the problem.
