Solution or Workaround
Why do I get the error message "Invalid serial number"?
Cause:
The International Registration numbers distributed with Atlas are incorrect.
Solution:
The number 3 should be inserted after the second number of the serial number you have received:
For example:
7969xxxxxxxx
should look like
79369xxxxxxxx
