English
Problem: Cannot install the open database connectivity (ODBC) files
Solution or Workaround
While installing Atlas GIS, the initial startup offers 4 choices:
- Atlas GIS Program Files
- Tutorial Files
- Data Starter Kit
- ODBC files
The ODBC files box is greyed out.
Cause:
Some of the system files may be missing or may be in the wrong location.
Solution:
To enable this option, make sure the following files are located in the Windows system directory:
      sming04.dll
sminf04.dll
sminf504.dll
For Windows 95, these files should be located in the \Win95\system folder.
For Windows NT, these files should be located in the \WinNT\system32 folder.
If you upgraded your operating system from Windows 3.x, the upgrade may have caused the misplacement of these files. If this is the case, reinstall Atlas GIS under the new system.
