English
How To: Fix if you select NO when asked to add new 3.1 tools to 3.0a proj
Procedure
Question:
How can I go back and fix/update a project file if I select NO when asked to add new 3.1 tools to a 3.0a project?
Answer:
Go into the system script 'Project.UpdateApr' (Open new script editor window and choose 'Load System Script' from the Script menu) and remark out the following IF statement:
if (aver = 30) then
if (theModGUI.Count = 0) then
return FALSE
end
else
return FALSE
end
Compile and run the script with the project file in question opened.
