Solution or Workaround
Summary
ArcView will not print to a Lexmark Color 1200 using the ArcView Enhanced PostScript option.
Cause
It appears ArcView's Enhanced PostScript is incompatible with the Lexmark Color 1200 laser printer.
Solution
Use the ArcView Basic PostScript option when printing to this printer. You may also try Native OS, or install and use the PCL5 driver for this printer.
