ERROR
An I/O subsystem driver failed to load - Reboot only in Safe Mode
Solution or Workaround
Summary
ArcView 3.1 and Crystal Reports installed successfully. After rebooting the system this error occurs:
Error: An I/O subsystem driver failed to load
Either a file in the .\iosubsys subdirectory is corrupt
or the system is low on memory.
Upon rebooting, a 'General Protection Error' message may also occur.
After this, the computer will only reboot in Safe Mode.
Cause
According to Microsoft, this problem may occur when all memory below 1MB is allocated prior to initialization of Ios.vxd. Ios.vxd needs memory below 1MB for use as real-mode buffers, if it can't do so, it fails to load, and Windows 95 fails to boot.
Solution
Edit the system.ini file as follows:
1. Find the area marked
[VCACHE]
2. Beneath it, type this line:
MaxFileCache=6144
You should now be able to reboot normally.
Article ID:000001509
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
