English
How To: Work with Name Dictionaries [SCRIPT]
Procedure
The script in this document shows you how to work with Name Dictionaries?
Answer:
The following script shows how you can work with Name Dictionaries
'--- Name Dictionaries use the name of the object (set with SetNme())
'--- as the Key and the Object itself becomes the Value.
'--- Make a name dictionary with a hashing table of 5
aNameDictionary = NameDictionary.make(5)
'--- Create some dummy key/value pairs and add them to the dictionary
astr1 = "Value 1"
astr1.setname("Key 1")
aNameDictionary.add(astr1)
astr2 = "Value 2"
astr2.setname("Key 2")
aNameDictionary.add(astr2)
'--- Get the list of keys to loop with
theKeys = aNameDictionary.returnkeys
'--- Presend the keylist to verify
msgbox.listasstring(theKeys,"The Dictionary Keys are:","Key List")
'--- Getting Info from the dictionary
'--- The Looping approach to dealing with elements
'--- Query each element by key - looping with each element
for each aKey in thekeys
aValue = aNameDictionary.get(aKey)
msgbox.info("The Key:" +TAB +TAB+ aKey +nl+ "The Value:"+TAB+
aValue.asstring, "The Key/Value Pairs:")
end
'--- The direct approach to getting values associated with the key
myValue1 = aNameDictionary.get("Key 1")
msgbox.info(myValue1.asstring,"Key 1 Value is:")
myValue2 = aNameDictionary.get("Key 2")
msgbox.info(myValue2.asstring,"Key 2 Value is:")
'--- End of Script
