Solution or Workaround
Using the RESELECT command on polygon features in ArcEdit or ArcPlot returns the message:
"Cannot open PAL file"
Cause:
The coverage topology has been altered or edited in ArcEdit and has not been rebuilt.
Solution:
Rebuild the topology by using the BUILD or CLEAN command.
Make sure that topology is present before displaying or querying the coverage.
