English
Problem: INFO REPORT with an OUTPUT file creates an incomplete file
Solution or Workaround
Summary
Running a report with an OUTPUT file creates an incomplete ASCII file.
Cause
The OUTPUT file was never closed by specifying another OUTPUT command or appropriately quitting out of the INFO session.
Solution
Before viewing or using the OUTPUT file, close the OUTPUT file by using the OUTPUT command again, or Q STOP out of the INFO session.
