English
How To: Move a coverage wth annotation to ArcView
Procedure
I have a coverage with annotation features. I want to move this coverage to ArcView. Should I use ARC ARCSHAPE command?
Answer:
Annotation is an unsupported feature class for shape files. You should use the ARC EXPORT command instead. The following example demonstrates what happens when a coverage named TEST containing only TIC and ANNO.JUNK features is EXPORTed.
Arc: describe test
Description of DOUBLE precision coverage test
FEATURE CLASSES
Number of Attribute Spatial
Feature Class Subclass Features data (bytes) Index? Topology?
ANNOTATIONS JUNK 49
SECONDARY FEATURES
Tics 10
TOLERANCES
Fuzzy = 461.582 N Dangle = 0.000 N
COVERAGE BOUNDARY
Xmin = -2359149.500 Xmax = 2256673.500
Ymin = 310203.813 Ymax = 3167703.500
STATUS
The coverage has not been Edited since the last BUILD or CLEAN.
NO COORDINATE SYSTEM DEFINED
Arc: arcshape
Usage: ARCSHAPE
{DEFAULT | DEFINE}
Arc: arcshape test anno.junk test
ANNOTATION.JUNK is an unsupported Feature Class for shape conversion.
test not converted.
Bailing out of CONVSHAPES
Arc:
