ERROR
List space exhausted (SEGLNK)
Solution or Workaround
Summary
CLEAN, IDENTITY, UNION, or INTERSECT return the following message:
Cause
The (SEGLNK) message occurs when too many segments end at the same node. ArcInfo overlay commands can handle up to 100 segments ending at a single node, and the CLEAN command can handle up to 20 segments ending at a single node.
Solution
Option 1:
Edit your data to reduce the numbers of arcs ending on same node.
Option 2:
Reduce the fuzzy tolerance to keep too many arcs from collapsing on a single node.
Article ID:000001415
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
