Solution or Workaround
Description:
The icon name specified in the DISPLAY field of a menu using the ICON option does not display. An empty box is displayed.
Cause:
A DISPLAY field requires a variable name.
Solution:
Set a variable equal to the pathname of the icon, place the variable name in the DISPLAY field and the icon will display correctly.
NOTE: Do not enclose the variable name in percent signs ( %variable% ).
Article ID:000001385
Software:
- ArcMap 8 x
- Legacy Products
