ERROR
PccOpen: Failed to Open Cursor
Solution or Workaround
Description:
When using EVENTMARKERS with an EVENTSOURCE in Microsoft Access, the following error occurs:
SQLSTATE:s1093, native error code: -1003
[Microsoft][ODBC Micorsoft Access 97 Driver] Invalid Argument
Solution:
The EVENTSOURCE Event Key item has as hyphen "-" or a pound "#". For example:
Source name : MIMARKERS
Event type : POINT
Event Table name: MILEPOST
Database : ACCESS
Relate type : FIRST
Route Key Item : WR-ID
Event Key Item : WR-ID
Point Measure : MILES
Rename the Event Key column to something without special characters.
Article ID:000001379
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
