English
Error: INSERT: Writing pass end of file
Solution or Workaround
Doing an INSERT of a line coverage into a Library returns the message "Writing pass end of file". What action should be taken in response to this message?
Cause:
The library .../DATABASE/INDEX coverage has no label points.
Answer:
Use the ARC command CREATELABELS to add labels to the .../DATABASE/INDEX coverage. Also make sure that the -IDs of the index coverage are unique.
Notes:
A library INDEX coverage must have label points and be built for polygons.
