English
Problem: Menus are too large to fit in screen
Solution or Workaround
A menu is too large for the screen. Some of the widgets are on the part of the menu running off the screen, and cannot be accessed. How can this be fixed?
Cause:
The font that the menus are using is too large.
Answer:
Reduce the size of the font used by ArcInfo menus, using as guidelines the following documents:
Related Information
