English
Error: Three common causes of FATAL ERROR (MSEEK)
Solution or Workaround
Question:
Why is the user bailed out of ARCEDIT with "FATAL ERROR (MSEEK)"?
Cause:
Usually the message is caused by one of the following:
Disk is full.
Not enough swap space is available.
The /tmp directory is full.
Answer:
1. Remove unnecessary files from hard disk to free up some space.
2. Increase swap space.
3. Delete files in /tmp that are not in use.
