English
Error: SDTSIMPORT: error reading LE01 module on Windows NT
Solution or Workaround
Error
Attempting to convert SDTS data downloaded from USGS produces the following error:
"error reading LE01 module (record #8)
missing FLIPS 123 subfield format definition
bailing out of ..."
Cause
The WinZip utility is corrupting the SDTS data. When the "TAR File Smart CR/LF Conversion" box is checked, the LE01 module is damaged. This causes the SDTSIMPORT command to crash.
Solution
SDTS data downloaded from USGS is g-zipped and archived in a .tar file. The popular utility WinZip can be used to decode and extract this data.
Prior to extracting the SDTS files with WinZip, the following must be done: from the OPTIONS menu select CONFIGURATION, click the MENU (or miscellaneous) tab and make sure the "TAR File Smart CR/LF Conversion" box is UNCHECKED.
Optionally
If a UNIX machine is available, the data can be decoded, extracted, and then transferred to the NT machine for ArcInfo processing. If the NT and UNIX machines are on a network, SDTSIMPORT will convert files across the network. If FTP is used for transferring, remember the SDTS files are in binary format.
If a UNIX machine is not available a different utility, such as "dostar" can be downloaded from the Internet, such as the "Java Resources" site:
http://www.javaworld.com/javaworld/common/jw.resources.toc.html
Unzipping and untarring the data on UNIX does not cause the problem discussed above.
SDTS data can be downloaded from USGS site below.
Related Information
