English
How To: Determine the number of selected records in DBMS using DBMSCURSORs
Procedure
How can the number of selected records in a DBMS table be determined.
Answer:
DBMSCURSORs can be used with the SQL 'select count(*)' sequence to find the number of selected records. The 'count' information can then be extracted into an AML variable.
The following example shows how to find the total number of records in an Oracle table, which allows column aliases:
DBMSCURSOR counter declare oracle select count(*) as colcount from oracle_table
DBMSCURSOR counter open
&s .num$sel = %:counter.colcount(*)%
DBMSCURSOR counter remove
(Applicable Databases: Oracle, Informix, Microsoft SQL Server, Microsoft Access)
The following example is for DBMSs that do not support column aliases, such as Ingres:
DBMSCURSOR counter declare ingres select count(*) from ingres_table
&s .num$sel = %:counter.col1%
(Applicable Databases: Ingres)
The AML variable '.num$sel' now contains the total number of records in the Oracle table.
Notes:
Cursors have an AML$NSEL reserved variable used to determine the number of records in a selected set. This variable is available for INFO cursors, but is not available for DBMS cursors.
