English
How To: Eliminate an annotation subclass
Procedure
How to eliminate an annotation subclass from a coverage.
Answer:
The following command removes the subclass:
ARC: DROPFEATURES coverage anno.subclass {geometry}
The GEOMETRY option removes everything: subclass name, TAT, and the
annotation as well. If the default option ATTRIBUTES is used, it only eliminates the Text Attribute Table (TAT), if one exists. The subclass still exists.
